Cadologist
en respuesta a: Anonymous
Have you tried to log into another different computer and print? See if the same results occur...... assuming not, they its pretty obvious it's something on your workstation or user profile. Have you confirmed that all the printer properties/settings are matching between your workstation and a coworker that can print the same file but without the heavy lines? Try to uninstall and reinstall the print driver for your large format printer?
A few suggestions or starting points anyway, process of elimination works good to resolve these sort of issues.  Good luck!!
Chad Franklin
