lbellino4
en respuesta a: weusethisforjunk
Did you create brand new tabs for each of these layouts? Sometimes when you start with a new tab and set from the beginning, it seems to work. I've attached a new drawing I created with 2 tabs set up to letter size as you have stated in your question and even after closing and reopening it, it retained the size/printer settings that I set it at and hopefully, this is what you're trying to do and helps. If this is not exactly what you're trying to accomplish, maybe if you attach an image of the issue, that may help explain the issue better.
