john.vellek
en respuesta a: Anonymous
Hi @Anonymous
It sounds as if the system variable PUBLISHCOLLATE was set to 0. This controls whether plotting a sheet set, multi-sheet plot file, or plot spool file can be interrupted by other plot jobs. Publishing sheets as a single job requires a plot driver that supports the multi-sheet plotting or printing option.
Type PUBLISHCOLLATE at the command line and set it to 1.
Now, try a publish job and see if things behave the way you are used to.
John Vellek
