07-16-2017
11:19 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
07-16-2017
11:19 AM
>> My goal is to having a solid that has one single surface at the top and 5 at the sides and bottom.
Well, your first drawing in your post has such a 3D-Solid.
>> In this case I cannot work with this solid because small small surfaces causes problem
>> with meshing process in FEM software
So you need to reduce the quality from the triangulated 3D-Solid ... but this triangulation was based on your contour lines.
So the way to go is back to Civil 3D, create a surface based on your contour lines, then reduce the quality (which tolerances are given for that process?)
After that recreate the 3D-Solid from the Civil 3D surface.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Alfred NESWADBA
