Alfred.NESWADBA
en respuesta a: Anonymous
>> What would u suggest me in that case ?
At least not using _EXPLODE.
Or when you want to start with the region objects you can use command _MESHOPTIONS to convert the regions to meshes, then run command _UNION and convert the meshes to surfaces.
But it's hard to say what would be the best for your workflow as I don't know your goal (and have not understood it from the other thread where I created that solid).
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
