- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
How to get the new tab on startup in AutoCAD 2015?
urrently when i open autocad it opens with a new drawing1, and i would like to open the new tab page like the image below.
I have tried to run with the settings below but still cant get the new tab page on startup...
NEWTABMODE = 1
STARTUP = 3
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I dont think that variable works in autocad 2015, this is what i get when i enter it:
Command: STARTMODE
Unknown command "STARTMODE". Press F1 for help.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
i suggest resetting your profile.
while no active command, type "op". go to "profiles" tab and click "reset" to reset.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
i tried the command "STARTUPMODE" but it is unknown. correct me if im wrong but i think what you are trying to imply is the command "STARTUP" where you can change variables from 0 to 3?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
STARTUPMODE must work in AutoCAD 2015 ... for that please try the below command and see if it's fixed.
Command: REDEFINE
Enter command name: STARTUPMODE
Imad Habash
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Command: REDEFINE
im gettting an unknown command name
and i did a google search for autocad STARTUPMODE and nothing came up, like there is not such variable...
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
STARTUPMODE is not an AutoCAD 2016 command or sysvar.
STARTUP = 3 and NEWTABMODE = 1 are my settings too, so I don't really understand why it does not show the same on your system.
May be resetting settings to default helps ... as described >>>here<<<.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
its not a command in AutoCAD 2015 either ![]()
Here in 2015, setting STARTUP to 3 and NEWTAB to 1 opens AutoCAD in drawing1.dwg without the NEWTAB screen. Reset doesn't alter that.
We set STARTUP =1 and use the "Startup or the Create New Drawing" dialog box.
