07-13-2017
02:17 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
07-13-2017
02:17 PM
projecting rectangle onto angled plane
I am currently working to create a 3-dimensional sleeve whose ends are not parallel. Here is a picture of the shaded exterior and a plan from the side. The part giving me trouble is creating the inside surfaces. The bottom has a uniform thickness, however the top has two walls of increased thickness because it is a cross section at an angle. For this reason I cannot simply offset the upper rectangle as I did with the lower. Somehow I need to draw rays parallel with the sleeve's outside that can be trimmed to the horizontal plane at the top of the sleeve. The wireframe picture shows my progress with one line passing through. Is there any way to trim lines with a plane?
