- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
Audit, Purge, and -Purge>Regapps is usually a great start to reducing file size. However, with all the items you are embedding into the file, I suggest that drawing setup is more likely the issue that needs your attention. Putting all of those files into a single AutoCAD drawing is not a great idea. If you have any drawing errors or corruption you are likely to lose most if not all of the data.
I suggest that you consider breaking the files up into more manageable pieces that perhaps use xrefs to link drawing data and datalinks to connect tables to Excel spreadsheets.
If you would like to share your file for me to examine, I am happy to send you an upload location.
John Vellek
