kadmonkee
en respuesta a: Anonymous
set your model space scale 1:10 msltscale = 1
set your Paper space psltscale = 0
create your viewport and set the scale of the open viewport =1:10.
if you need to use multiple viewport scales on your sheet in paper space be sure to set the viewport scale correctly.
See process in the image
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
