oswaldodcb
en respuesta a: Anonymous
Hi @Anonymous,
When you define an annotative scale you must establish it from the list of scales, those are the predefined scales, you can insert custom scales depending on the scales you need. If you do ZOOM WINDOW will not give you result because that way not defining an exact scale, try to take that drawing to a commercial scale, or else set the scale you need and add it to the list to make it easier. For example, if ZOOM WINDOW generates a decimal scale of 0.046448, divide that value by 1, which would result in 21.52945 ..., with that value you can add the annotative scale to the list,
I attached some images to see the procedure:
Once done, you can add that annotative scale to your texts and other annotative objects,
I hope it will be useful,
Regards
Oswaldo Caballero
Project Engineer / Autodesk Certified Instructor / Autodesk AutoCAD Certified User and Professional
Maracaibo, Venezuela
LinkedIn
Da un Me Gusta si la publicación ha sido de utilidad y si ha resuelto tu duda presiona ACEPTAR SOLUCIÓN
