- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi, I am trying to learn and apply annotative scaling to my drawings. I have gone through a number of tutorials for the same. When I organise drawings in different viewports in paper space (layout), I use the command "zoom" ENTER "window" ENTER to scale the detail to the required size (i.e, the tab on the right hand corner shows the scale in decimal form). So when I tried annotative scaling, I used the same command to scale my details but the text or dimension did not modify accordingly. P.S- I have the "Automatically add scales to annotative objects when the annotation scale changes." switched on. The same command seems to work when the viewport is set to a definite scale, for example, set scale being 1:10 and I modify it to 1:20. annotation works. Let me know if you guys have a solution for this.
¡Resuelto! Ir a solución.
