3511 Vistas, 7 Respuestas
how to reduce dwg file size?
Hi Sir,
My new autocad File size is 27 MB. It have 40 OLE objects ( 37 spread sheet and 3 jpeg ). I need to reduce the file size below 18 Mb.
I am using AutoCAD 2014.
Alfred.NESWADBA
en respuesta a: Anonymous
I guess the global tools like _PURGE were already done?
Otherwise delete objects from your file or copy the objects to different files and use _XREF to show them as like in one file.
In general: when a drawing needs that space you can't say reduce the size without deleting something. It's like having a car with 1800Kg and you say "reduce the weight to 200Kg" ==> that car will not be functional any more.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
Audit, Purge, and -Purge>Regapps is usually a great start to reducing file size.  However, with all the items you are embedding into the file, I suggest that drawing setup is more likely the issue that needs your attention.  Putting all of those files into a single AutoCAD drawing is not a great idea. If you have any drawing errors or corruption you are likely to lose most if not all of the data.
I suggest that you consider breaking the files up into more manageable pieces that perhaps use xrefs to link drawing data and datalinks to connect tables to Excel spreadsheets.
If you would like to share your file for me to examine, I am happy to send you an upload location.
John Vellek
scot-65
In addition to John's suggestion and you did not state
if the file was created using verticals (proxies). Keyword
search in this forum "Purge Dictionary Items" or "PDI".
This will remove *unnecessary* dictionary items that are
not "ACAD_" based (the user must enter keywords to
execute).
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
I recommend to visit Autodesk App store and then search Purge.
Then You can see a lot of plug-in about the purge.
Read manual and use it that you want!.
https://apps.autodesk.com/All/en/List/Search?query=purge&isAppSearch=True
I have been using Drawing purge from the app store.
I think that is useful to clean drawing and easy to use.
john.vellek
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
en respuesta a: john.vellek
Thanks for your valuable information,If you provide me the mail ID, I will try to send my file
john.vellek
Hi @Anonymous,
You are welcome to email me the file at john.vellek@autodesk.com
John Vellek
