294 Vistas, 3 Respuestas
AutoCAD 2017 Freezes
  i have autocad 2017 and i started the drawing around 1 or 2 min.later that is freezed plase help i cant do anythınk by the way is there any turkısh
   support service  also when ı take this freeze a few  minutes later my pc (monster abra v6.3)(win 10) showed blue screen and there was a warning that like posted
john.vellek
en respuesta a: Anonymous
Hi @Anonymous,
This sounds like it might be a graphics card driver.  Did this just start happening?  I would check for a newer driver.  What make and model card do you have on your computer?
Which version of AutoCAD are you using?
John Vellek
J.FOCHT
You can try and check to see if there are any service packs or updates available for your software. As another possible solution you can uninstall and reinstall the software. This article is helpful and can be translated into Turkish.
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCA...
If this helps you then hit the LIKE button or mark as an ACCEPTED SOLUTION!
Thank You!
Jonathan Focht
john.vellek
Hi @Anonymous,
I am checking back to see if my post or @J.FOCHT's helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
