07-12-2017
12:42 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
07-12-2017
12:42 AM
>> DWG to PDF and AdobePDF generate text that looks inconsistent and hard to read
I don't speak about Adobe PDF, my suggestion is only "DWG to PDF".
And in most cases a text is not displayed properly in the PDF it's a setting, but not the driver generally.
Would be great to work with a drawing and compare then the results.
>> publishing them all with files open and not using .dsd, and it did not work correctly.
What means "did not work correctly"?
Referring to your 2 PDF's - which I understand they were both done with drivers you don't like - I'm missing the PDF that you create with your driver to see what is better with that output.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Alfred NESWADBA
