Alfred.NESWADBA
en respuesta a: Anonymous
>> because the OTB publish to PDF driver gives us bad results. We use a third party plotter,
What is bad when using the internal PDF drivers (as long as you have not used migration from previous AutoCAD versions)?
For me the internal driver is the most stable one, creating higher quality PDF's with less file-size (compared to others).
Using 3rd party plotter might create more conflicts and I would look into the Foxit settings, maybe it's updated or there were settings modified?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
