1813 Vistas, 3 Respuestas
Cannot enable hardware acceleration Autocad 2017
I've recently updated the AMD RADEON Drivers, and I started having problems with Hardware aceeleration.
It began changing the colors (when hardware acceleration was on) but now, If I turn it on, it would inmediatly crash.
I can work with the acceleration off, but it works slow, and it´s hard to even draw a line.
I have a LENOVO IDEAPAD, WIN 10 64bit, AMD RADEON R7 M360, 16MB RAM, i7 2.7Ghz
Etiquetas (1)
lim.wendy
en respuesta a: Anonymous
Hi there,
When AutoCAD crashes, did it give you the option to submit CERs report?
Can you submit it and use the email address for you register?
I don't see your graphic card listed as supported. Here is the link: http://usa.autodesk.com/adsk/servlet/syscert?siteID=123112&id=18844534&results=1&stype=graphic&produ...
Usually having the latest driver from the manufacturer is best. Try uninstalling and reinstalling it again. The way to do this is to download the installer for the video driver, then uninstall your current driver, reboot, then install the driver again (or an updated/different version), and reboot once more.
Cheers,
Wendy
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
imadHabash
maybe it's graphic card problem ... try to read and follow this AKN articles that it could help. Link ,  Link 1
Good Luck..
Imad Habash
gaurav.satalkar
Sorry for the inconvinience caused.
This problem may be related to outdated video drivers.
Thank You,
Gaurav Satalkar
QA Engineer
