BeKirra
en respuesta a: mohsin_160
@mohsin_160 wrote:
... I saved the drawing and everything is going OK. The issue is that the next day when I opened the same drawing, the components are misplaced...
[joke]
Answer: You are writing a scary story and telling us that something happened in the midnight when nobody was around.
Yes. the attached screenshot is what I see from your drawing. And I don't find any errors from your drawing file.
I don't find the top panel which showed on your screenshot.
I have tried to rotate the view to see if any view point matches what you showed but only can understand your frustration.
Suggestion:
What if you remove all the misplaced components then copy the right support panel showed on my screenshot to the left?
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
