07-04-2017
01:32 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
07-04-2017
01:32 PM
Hi @apstevenson,
If you need to keep the text at the same height, I suggest you see from the property bar the elevation of the text, once exploited you will see that the elevation will be 0, you just have to take all the lines, go to the same property bar and Place the elevation you had before. You only have to modify the Elevation because the position X and Y lie same,
It's the simplest thing I can think of,
I hope it is useful,
Oswaldo Caballero
Project Engineer / Autodesk Certified Instructor / Autodesk AutoCAD Certified User and Professional
Maracaibo, Venezuela
LinkedIn
Da un Me Gusta si la publicación ha sido de utilidad y si ha resuelto tu duda presiona ACEPTAR SOLUCIÓN
