john.vellek
en respuesta a: Anonymous
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
 This wasn't as bad as I thought it might be. Swapping 3D geometry can sometimes be a bit tricky and messy.
I worked on individual parts separately. I started with the hub pieces and used SMOOTH and SurfSculpt to turn them into solids. If they were stubborn I would first use  a UNION.
The only parts I as uncertain about are the ones shown in this image.  You could give them thicknesses or create them using AutoCAd SOLIDS but I wasn't sure how they were to interact.
I have attached my version of your file to look at.
Once you finish these four parts, you should be able to create nice and clean Viewbase views in your layout.
John Vellek
