en respuesta a: john.vellek
Hi John,
After messing around with this for a while I think I have narrowed down the issues.
Though it isn't a complete solution I think i managed to get around this and help with the workflow.
- Polyline grips and "ghost lines" that was displayed as per screenshots previously when selected.
I never noticed this but I believe this is always been like this after testing on 4 different machines with different autocads.
# 1 Visual styles
I always work with 2d wireframe most of the time which doesn't display the issue. When you switch to any other visual styles (for drafting with recap for example) however and zoom right in the issue occurs. (see SS attached)
#2 drawing units
This is further disrupted if you're like me in the surveyor engineering industry and usually draw in metres.
As far as the point cloud is concerned my only work around for now is to 1- draw in mm and 2- unify a RCS file to draft from.
Could you see if the screenshot is the same for you or anyone else viewing this post?
