- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
UNDERLINE & OVERLINE
WHEN I SIMPLY `CHANGE CASE' OF TEXT ACROSS A DRAWING USING MODIFY TEXT, FOR SOME REASON ALL CONVERTED TEXT APPEARS IN A FORMAT WITH BOTH UNDERLINE & OVERLINE ON EACH WORD OR NUMBER. IS THERE A WAY OF DISABLING THIS FUNCTION OR A WAY OF PERFORMING A SWEEPING CHANGE WHICH ADJUSTS THE FORMAT SO BOTH THE OVERLINE & UNDERLINE DISAPPEARS ?
THANKS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Is the MODIFY TEXT a lisp or net routine? Or is it standard AutoCAD?
It sounds like it is a lisp routine that adds the underline %%U or overline %%O to the text.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Your AutoCAD version is what?
Your Windows version is what?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
Can you share your file and the lisp routine you are using to modify the MTEXT?
John Vellek
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
HI @Anonymous,
I am checking back to see if my post or others helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
