user181
en respuesta a: liam.mulcahy
Hi @liam.mulcahy you can freeze a layer in the whole drawing while in a viewport. When you select the freeze button on the ribbon you have options on the command line. Choose S for settings then select V for viewports the choose F for freeze instead of the other option vpfreeze then select objects in drawing to freeze and their layers will be normal freeze instead of a viewport freeze.
