06-23-2017
12:12 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
06-23-2017
12:12 AM
Hi Li
You are running the latest windows so you should be fine for AutoCAD 2016-2018. You do however need to check your graphics card because that could be a limiting factor. If your graphics card is not up to spec then you can use the /NOHARDWARE variable to launch the product.
- See this link for the /NOHARDWARE variable -- https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Starti...
- You can check the AutoCAD min requirement here -- https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/System-r...
- You can also check the Graphics requirement here -- http://usa.autodesk.com/adsk/servlet/syscert?siteID=123112&id=18844534
You are able to download the software various ways
- Autodesk account page -- https://accounts.autodesk.com
- AutoCAD product page -- https://www.autodesk.co.za/products/autocad/free-trial
If you do not have an Autodesk account with the product listed or you need an older version of the software then you can use the Autodesk virtual agent.
- This link will show you how it works -- https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Obtain-Older-Products-Do...
- This is the link for the download of the software -- http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk...
I hope this helps
Regards
Marnus van Staden
Technical consultant & Civil 3D support Specialist
Prokon Software Consultants
Kind Regards
Marnus van Staden
N.DIP Civil Engineering | Senior Technical Specialist
Autodesk Trainer | Draughting Consultant
________________________________________________________________________________________________
If you find my post useful, please give me Kudos. If my post solved your problem, please accept it as a solution.
Apex Solutions Youtube Channel
