- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
3D orbit and other 3D manipulating methods-Solid disappears at the beginning
I press the middle mouse button+Shift and the model rotates, O.k. but immediately as i start rotating the solid disappears and i zoom to extents to find it.
It happens also when i start the 3D orbit command.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
try to change visual style.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
have you tried to select the object (or objects) before you start orbiting, by default AutoCAD will then hold the center of that objects as fixed center of orbiting.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
When first i select a solid and then orbit it behaves the same as when not selecting-it moves much out of the view.
How can i control how much it moves as a function of the mouse?
How can i make that the orbit center, as you say, will be in the solid i selected? which variable stores it?
Changing the visual style doesn't change anything.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Look to the sysvar ORBITAUTOTARGET (>>>details<<<).
If that does not help and this issue only appears in that one drawing, then please upload the drawing so we can look into the details about that 3D Solid.
- alfred -
Alfred NESWADBA
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Here is what happens when i start the 3D Orbit, the model jumps.
There is no sys var ORBITAUTOTARGET but there is Enable Auto Target on the shortcut menu during the 3D Orbit command. i used it but it doesn't help.
Alao, the model gets stuck in some positions, i can't rotate any more
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
3DORBITCTR doesn't help. but it's strange, the first time i used it it was O.K., the model rotated without jumping to some position at the beginning.
But look also what happens when i try to rotate more-i can't.
I recorded a screencast, it said it's been uploaded but it's not in the list.
As soon as it wil be i will attach
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
just to remind... please if your model far a way from 0,0,0 please move it near to 0,0,0 and see how it's work.
Imad Habash
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
>> Now you can see how it gets stuck. <<
honestly... i review your screencast many times and i don't see any stuck..
Imad Habash
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
It doesn't stuck, i can rotate all the time but it gets locked in 2 positions: horizontal in both directions: the TOP and BOTTOM views, and even though i drag the mouse the model doesn't continue. i can only rotate between those 2 views.
I attached a simplified file.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
There is a toolbar called Orbit as you see in my attached screencast and there is 3 types of orbit. are they ok for your issue.:)
>> Screencast <<
Imad Habash
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
In constrained orbit it doesn't work as in your screencast, but in free orbit yes
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Press Shift+W, press and hold Orbit.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
With the SteeringWheel it works fine, it doesn't jump. and it also works with Freeorbit, but with Constrained orbit it jumps as i press the mouse button.
And, also, the rotation of the model is constrained between 2 states, as i said.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
This also happens to me but only when i have external references set to a layer that is frozen.
It takes for ever for the 3DO to execute for the first time, i press escape, it resumes with no graphics, when i quit the command i see the graphics.
The next time i try the 3DO it works instantly but it shows no objects until i quit the command.
Thawing the layer that contains the external reference everything works as expected.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
One of the solutions is:
command: GRAPHICCONFIG ---> In Effects Settings switch off Hardware Acceleration.
