- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
@Anonymous wrote:
I cannot delete or copy or at least right click and take the properties of any drawn object in my autocad. ....
I don't think a locked Layer or the PICKFIRST setting can be the issue, because in either case you would still be able to get an object's Properties.
If PICKFIRST isn't set right, you could still delete or copy things, but would just need to select them after calling up the command, not before. Are you able to do it that way?
If there isn't anything wrong enough to require a REPAIR, then the only thing I can think of is that the objects you're trying to do something with are on the DEFPOINTS Layer and Layer 0 is off or frozen, in which case things on DEFPOINTS can't be selected or object-snapped to, even though they are still visible. But that wouldn't affect things on any other Layer. Do you have the same problem with things on various Layers?
