oswaldodcb
en respuesta a: Blue2012
Hello @Blue2012
Welcome to the AutoCAD Community!!
For AutoCAD 2014 there may be some kind of incopatibilidad for Windows 10, that is why I recommend that you uninstall AutoCAD and also the .NET 4.6, also Microsoft is officially recommending that users uninstall .NET 4.6 prior to installing any blocked Autodesk software, and then reinstall .NET 4.6 afterwards.
I append the solution that Autodesk poses where you can see the possible solutions for each version:
https://forums.autodesk.com/t5/autocad-forum/autocad-2015-windows-10-preview-fatal-error/td-p/531743...
I enclose a solution raised previously in the forum:
If you can install a more current version would be much better, you can try downloading and installing a trial version of a more current version:
https://www.autodesk.com/education/free-software/autocad
I hope it helps you,
Oswaldo Caballero
Project Engineer / Autodesk Certified Instructor / Autodesk AutoCAD Certified User and Professional
Maracaibo, Venezuela
LinkedIn
Da un Me Gusta si la publicación ha sido de utilidad y si ha resuelto tu duda presiona ACEPTAR SOLUCIÓN
