mromagnoli
en respuesta a: Anonymous
Dear Spectre24:
The images in AutoCAD are external references, then you must save to the DWG all the PNG so that you can open it on the other computer without problems.
Save everything in the same folder and you will not have problems opening it on any computer.
recommend you publish the file with the option "e-transmit" that collects all the necessary information so that the file can be opened anytime & anywhere.
i leave a screen shot that might help you.
Best regards
Arq. Marco Romagnoli
AutoCAD Certified Professional | Revit Certified Professional | 3Ds Max Certified Professional | Fusion Certified User | Autodesk Certified Instructor | VRay Certified Instructor
