john.vellek
en respuesta a: a.apel
Hi @a.apel,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
This is likely a driver issue as suggested by @J.FOCHT.
Does it happen in all drawings or just specific ones? I unique to select drawings I suggest you run AUDIT, PURGE,-PURGE>Regapps to clean the files. If there are XREF files involved use RECOVERALL
John Vellek
