john.vellek
en respuesta a: Anonymous
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
I don't have a version older than 2016 currently but I would be happy to convert your file if you attach it to a post.
Note however that I will likely do this in Inventor or Fusion 360. Here are the export formats for AutoCAD. If one of those will work, just start EXPORT in AutoCAD and select the file type in the dialog window. Then select the objects to export.
John Vellek
