a.apel
431 Vistas, 2 Respuestas
FATAL ERROR:Unhandled Access Violation Reading 0x0000 Exception at 58036c26h
Any ideas what this is about. Started coming up a lot recently
J.FOCHT
en respuesta a: a.apel
Check to make sure your graphics card has the latest driver version. That may be the culprit.
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCA...
If this helps you then hit the LIKE button or mark as an ACCEPTED SOLUTION!
Thank You!
Jonathan Focht
john.vellek
Hi @a.apel,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
This is likely a driver issue as suggested by @J.FOCHT.
Does it happen in all drawings or just specific ones? I unique to select drawings I suggest you run AUDIT, PURGE,-PURGE>Regapps to clean the files. If there are XREF files involved use RECOVERALL
John Vellek
