254 Vistas, 2 Respuestas
Have sudde
I have begun to have the following error message when starting AutoCAD, "Customization file load failed. File not found" The session then locks up.
Any suggestions??
oswaldodcb
en respuesta a: Anonymous
Hello @Anonymous
In Autodesk there is a procedure to follow that error, I added the link:
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-Customization-file-load-failed-File-not-found.html
In addition to the solution proposed by another member of the community,
https://forums.autodesk.com/t5/installation-licensing/customization-file-load-failed-file-not-found-enu-support-acad/td-p/6626442
I hope it will be useful,
Oswaldo Caballero
Project Engineer / Autodesk Certified Instructor / Autodesk AutoCAD Certified User and Professional
Maracaibo, Venezuela
LinkedIn
Da un Me Gusta si la publicación ha sido de utilidad y si ha resuelto tu duda presiona ACEPTAR SOLUCIÓN
john.vellek
Hi @Anonymous,
Did @oswaldodcb resolve your issue with the great suggestions? If so, please reward the post  with a Kudos and please also mark the post as an Accepted Solution(s) that resolved the issue.
John Vellek
