1079 Vistas, 18 Respuestas
Layout colors don't update in one drawing
Having an issue with my layout colors I am using AutoCAD 2015
My layout color preferences show correctly in most documents, like this:
In One of my drawings, this is what the layouts look like with the same options settings.
Etiquetas (2)
en respuesta a: Anonymous
.... but it has no effect on the plot ...
Plotting is fine, changing those options doesn't do it, since it is only an issue on a single drawing.
imadHabash
HI,
>> i want this area to change as well <<
it's not clear to understand ... is there VP in that area or what? please describe exactly what do you need :cara_con_una_leve_sonrisa:
Imad Habash
Its not an issue at all, it is simply cosmetic on-screen, I turn it all off.
Check, sheet size in the page setup, make sure its set current for the layout tab and
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
If this is truly happening with only one drawing, is it possible to attach it to a post so I can examine the issue?
John Vellek
en respuesta a: john.vellek
OK, I purged essentially everything out of the file, since I wouldn't want to distribute the architect's work without their permission, I also hoped that doing that and then auditing might have resolved the issue.
Note in the file that the paper background is CYAN, but that only seems to affect the paper shadow and those horizontal lines (which do not appear to be objects)
Hopefully this file will show that the issue is isolated to the paper background element in the sheet/layout context,
Alfred.NESWADBA
besides of the missing CTB ... that is what I get:
How does it look like on your screen?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
john.vellek
Hi @Anonymous,
I too see the same thing as Alfred does.  If this is only happening with one drawing I suggest perhaps moving all the drawing elements to a new file.
I was able to purge objects out of this file and it also had many REGAPPS when I used -Purge>Regapps. Perhaps that is part of your issue.
John Vellek
john.vellek
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
en respuesta a: Alfred.NESWADBA
Just when I was ready to assume it was the file... mine looks like this. the paper border and those lines that extend to the sides are the only things that change when changing the color of the paper background
john.vellek
Hi @Anonymous,
I wonder if this is display card related. Can you tell me the exact version of AutoCAD (hotfixes and service packs applied) as well as your operating system and graphics card make and model?
John Vellek
Is this enough? I am not sure how to get any more info on patches, etc..
john.vellek
Hi @Anonymous,
This helps. Please tell me which version of Windows you use.
Then in the device manager control panel (in Windows) fin the graphics card and tell me the make and model.
John Vellek
Windows 7 professional SP1
john.vellek
Hi @Anonymous,
Please go here to see if there is a more current driver for your card.
Please also open GRAPHICSCONFIG in AutoCAD and send me a screen capture of the window that opens.
John Vellek
An update,
As I was working on this drawing, I noticed another display issue Note the different displays of the same block.
Just popping this up there to see if it triggers anyones memory about perhaps how fills are displayed/plotted
This is the case for all of my blocks that have filled regions
john.vellek
Hi @Anonymous,
Try setting FILLMODE=1 and let me know if this corrects the issue.
John Vellek
MY HERO,
That was it!!!!!
Tried to see if I could click kudo more than once for this one. My eyes (and drawings) are saved!
Thanks for sticking with me on this!
(in case anyone reads this in the future, entered the command in paper space, and the main background updated as soon as I zoomed, to get it to fix my blocks in paper space I had to REGENALL, and that did it)
