- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Is there a driver update from Autocad that will allow a user to plot directly to an HP T2500PS plotter from R13 or 14. Currently we have to save it as a pdf and then plot it.
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Autodesk does not write plotter drivers, what problems do you have?
>> from R13 or 14
I guess you mean 2013 and 2014?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
plotters from the HP 1055CM + to the T2500PS emfp.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
>> I mean R13 from 1994 and R14 from 1997
Wow, and your operating system is?
Wasn't Windows 3 and Windows NT the last supported operating system for these releases? I guess you won't get any drivers today for such old operating systems.
Please describe your exact environment and also please let us know which problems you have.
- alfred -
Alfred NESWADBA
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Start testing with your old HP1055 drivers and some of the built in old HP drivers available to you in plottermanager command.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
Does HP provide a driver for your operating system? That is likely the starting point.
You might be able to print to this networked device in AutoCAD using AutoSpool.
PDF though is probably the best method for such an old system.
John Vellek
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
