- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous
As mentioned by @imadHabash, dimensions of the file has different properties, when you select the MATCH command, you copy the dimensions style, in this case the "Annotative" style, which does not have some features such as paper text height.
Also some dimensions are annotative and others not, when you apply MATCH you can copy the properties of dimensions No Annotative to others that if and turn them into No annotative, but vice versa does not work.
What I recommend is that you select all the dimensions and from the properties box you assign the same properties to all. And to avoid future problems, personalize your dimensions style well and make sure they are all annotative.
I hope it will be useful
Oswaldo Caballero
Project Engineer / Autodesk Certified Instructor / Autodesk AutoCAD Certified User and Professional
Maracaibo, Venezuela
LinkedIn
Da un Me Gusta si la publicación ha sido de utilidad y si ha resuelto tu duda presiona ACEPTAR SOLUCIÓN
