5981 Vistas, 7 Respuestas
Use MATCH function to dimensions
I use a MATCH functions to dimensions. I want them to be consistent. However, only the color change, the size doesn't change. I check the properties of the dimensions, both of the use the same style. How to keep them the same style? ThanksCapture-wwww.JPG
user181
en respuesta a: Anonymous
After you issue the MATCH PROPERTIES command and select the first object and before selecting the objects to make match select the setting on the command line and see if the box is checked for dimensions.
en respuesta a: user181
I have selected all items in the march settings panel. Just the size of text won't be matched
imadHabash
would you please attache these dim here as a CAD file for testing?
Imad Habash
en respuesta a: imadHabash
Here is the file.
I want to match the small size dimension to large ones. Thank You
user181
MATCHROP worked for match the dimension on my pc. Are you sure your using MATCHPROP and not LAYMCH (layer match)?
imadHabash
as seen from the below image the properties for the dimensions are different !!! there is manually changes occurs.
Imad Habash
oswaldodcb
Hi @Anonymous
As mentioned by @imadHabash, dimensions of the file has different properties, when you select the MATCH command, you copy the dimensions style, in this case the "Annotative" style, which does not have some features such as paper text height.
Also some dimensions are annotative and others not, when you apply MATCH you can copy the properties of dimensions No Annotative to others that if and turn them into No annotative, but vice versa does not work.
What I recommend is that you select all the dimensions and from the properties box you assign the same properties to all. And to avoid future problems, personalize your dimensions style well and make sure they are all annotative.
I hope it will be useful
Oswaldo Caballero
Project Engineer / Autodesk Certified Instructor / Autodesk AutoCAD Certified User and Professional
Maracaibo, Venezuela
LinkedIn
Da un Me Gusta si la publicación ha sido de utilidad y si ha resuelto tu duda presiona ACEPTAR SOLUCIÓN
