- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
can anyone help me to understand why some 3D solids disappears or not show in AutoCAD 2013 version.
But when I open this attached file in newer versions (2014...2018), it looks fine.
Any ideas how to fix this?
I would be very grateful for any response.
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
if you move all the 3d solid object 250 to up direction;any differences?
Imad Habash
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @praila,
I no longer have AutoCAD 2013 installed so this is hard to test. I don't see anything unique with the drawing however. Can you try to copy and paste into a new file to see if that makes any difference? You might also consider a Reset Settings to Default in AutoCAD 2013.
John Vellek
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi John,
Thank you for trying help me. Yes I tried to copy > paste in new drawing, also wblock and all other variations but unfortunately...
I'm working with 2017 version and could be that this solids I made with newer version and somehow affected visual drawing reading opening it with 2013 ?
I'm creating piping supports library and testing with fresh installed 2013 version and I found this "bug" in several modeled parts.
Maybe there is any way to open this drawing with Inventor Fusion and re-save it to DWG or step files?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @praila,
I took the file into Inventor and also into Fusion. I have attached the exported files here for you to try in your AutoCAD 2013. Please post whether these make any difference.
John Vellek
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
wonderfull, it works!
Resume:
best converted files - FromIgestofusion.step, 350MA52_H150 v1.step (became same great solid elements)
medium - 350MA52_H150.iges (because all elements became surfaces)
worst - 350MA52_H150-Inventor_Layout1.dwg (because don't show any element)
John - thanks a lot for your patience!
Now I know the way how to correct those mysterious files. The only question as elements become invisible. I'll try to indicate this in the future.
