oswaldodcb
en respuesta a: njbrien
Hi @njbrien
When you change your UCS are you applying the PLAN command? Since you can rotate your axes with respect to the new UCS, so place your UCS and once established type PLAN, press enter and then enter. Maybe your block works well,
I put a link of the command PLAN (Current UCS Generates to plan view in the current viewport relative to the XY plane of the current UCS.)
Http://help.autodesk.com/view/ACD/2017/ENU/?guid=GUID-3779DF52-AA24-47D2-B72C-018D4A9011DD
I hope it helps you
If my publication solved your concern Accept the SOLUTION
Oswaldo Caballero
Instructor ATC
Autodesk AutoCAD Certified User
Venezuela
Oswaldo Caballero
Project Engineer / Autodesk Certified Instructor / Autodesk AutoCAD Certified User and Professional
Maracaibo, Venezuela
LinkedIn
Da un Me Gusta si la publicación ha sido de utilidad y si ha resuelto tu duda presiona ACEPTAR SOLUCIÓN
