- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Have made a couple of modes in Autocad 2017 and they ca be successfully imported into 3ds max 2016 . On installing Autocad 2018 same models when saved in 2018 version won,t import into 3ds Max 2016 ? Also i found that Fbx export does not want to work either in Autocad 2018?
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
It depends on how you import the AutoCAD model into 3DS-Max, if you use the DWG-file then no, AutoCAD 2018 uses a new dwg file format and that new format is not known to 3DS-Max 2016.
You might try command -EXPORTTOAUTOCAD and chose the DWG2013 format .. .that should be working well with 3DS-Max 2016.
What means "does not work" ... what do you do and what is the result, which messages do you get, ...?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
