en respuesta a: acadhelp1
@acadhelp1 wrote:
I would change this up a little.
To use the New Layout from Template, you will need to insert your titleblock on to a layout. Then save it as a template.  So here is what I did with your file.
  1. Opened B.dwg
  2. Converted the title block to a block named TitleBlock
  3. I created a B size layout using Page Setup Manager
  4. I inserted the title block on the new B- size layout
  5. Save as a template file.
Now you can use the from template option to create your layout.
I will attach the screencast after upload and publish completes.
Thank you very much for your time in creating the screen cast for me. Can you explain to me why when I try to insert my title block to a drawing in model space with my method the title block is sometimes are to small or to large does or does not show at all. It worked for other files.
