- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hey hive brain,
I'm experimenting with something here. I am trying to print from straight from AutoCAD to an Epson T20II thermal receipt printer. I'm able to send a file to the printer, however, it only plots a tiny portion of what I'm asking it to print. Essentially, I need it to plot continuously. It appears that it is limited to the paper size identified in the plotter profile. I've tried to create a new size but it doesn't seem like its an option in either the profile in CAD or in the control panel in Windows.
One thing worth mentioning, is that I can successful send it to the DWG to PDF "plotter" and it spits out the file correctly. Then, I can send it to the receipt printer and it will print what I have selected. I have yet to test something more than ten feet but I feel like this might be a worthy work around. The challenge is that I am experiencing some scaling issues... which I can probably figure out.
I admit, plotter profiles are not my strong point. I can get by with setting up a plotter or desktop printer to see a file. The minor tweaks and troubleshooting are the challenge for me.
Has anyone ever attempted this? I know its something that is pretty specific to my industry. Although I've never experimented with it, Vectorworks Spotlight has a plugin that allows you to do what I'm trying to do. Here is a link to get a better idea what I am trying to accomplish.
Thanks in advance.
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous,
Interesting problem! So, I can download the printer driver and get it installed. Do you have a sample drawing that you can share? There isn't a way for me to actually print the file but I would like to see if I can get the preview of the print to work properly.
John Vellek
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Absolutely. File is attached.
Essentially, its a file with our blocks redefined to fit on the width of the paper. At the moment there are only a couple blocks, so its a work in progress.
Thanks for taking the time to look at it.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous,
It appears that the longest the driver allows you to print is 3276 mm (approx. 128") and has a width of 90mm.
So, I created a rectangle that reflects this max size and copied it onto your truss length with some overlap. Now, I can print (in theory because I only have a preview) using a window selection to create three separate plots of max length.
Does this make sense?
John Vellek
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
That is very interesting. I was afraid that was the case. There must be some line of code that allows the Vectorworks plugin to print continuous lengths up to 120'.
I should be able to utilize that method as I believe there is a way to prevent the printer from sniping the paper after the print is complete.
I see that it is overlapping. Would I simply be able to line up the windows if I wished to print a substantial length without having to have overlap?
