acadhelp1
en respuesta a: Anonymous
I would change this up a little.
To use the New Layout from Template, you will need to insert your titleblock on to a layout. Then save it as a template.  So here is what I did with your file.
  1. Opened B.dwg
  2. Converted the title block to a block named TitleBlock
  3. I created a B size layout using Page Setup Manager
  4. I inserted the title block on the new B- size layout
  5. Save as a template file.
Now you can use the from template option to create your layout.
I will attach the screencast after upload and publish completes.
Jon Page
AutoCAD Design Manager
