john.vellek
en respuesta a: Anonymous
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
It seems this was not added to your original thread.
Are you using AutoCAD 2018 and publishing using the built in DWG to PDF driver?
I assume the text in question is annotative scaled. Is it inside a block?
Is it possible to add sample drawing that displays this behavior?
John Vellek
