neaton
en respuesta a: Cadologist
Thanks! I had purged the steps block and could have sworn I redefined the cleaned up block but when I wblocked it out of the castings file it still had the unused dimstyle.
@Anonymous wrote:
It appears that you have a nested block within the dynamic block (Casting DYN.dwg) called StructSteps-tops.dwg,which has a purgable dimstyle CCP-Dim Style contained within it. If you PURGE that item out of the StructStep-tops block it'll should be gone.
