Cadologist
en respuesta a: neaton
It appears that you have a nested block within the dynamic block (Casting DYN.dwg) called StructSteps-tops.dwg,which has a purgable dimstyle CCP-Dim Style contained within it. If you PURGE that item out of the StructStep-tops block it'll should be gone.
Chad Franklin
