- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Yes, I've done a search, tried the listed solutions, no they don't work.
I run Autocad 2016, viewed on two screens. I can use the layer pull-down, but the Layer Properties tab does a bizarre thing: I click once, the screen flashes, (always a different type of flash---sometimes white, sometimes blue). This doesn't happen with any other Autocad tool, or any other program.
where did it go? help.
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
3 things to try (for now):
- move your AutoCAD to the other monitor and try again to start the layermanager.
- make sure that no other software is started (besides of Windows services
- login with another Windows user account and let's know if the same happens there
If that does not help please let us know which graphic card and operating system you are using (for graphic card ==> which driver).
Also make sure you don't have a desktop manager as separate tool running (so you might switch between different screens/desktops).
Does that mean that both displays are painted in the same color? All existing windows as well as desktop background are not visible any more?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I have the same problem in 2018. Every other tab on the ribbon will pin or show up, just not the properties tab.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
what have you tried from my suggestions and which result(s) did you get?
- alfred -
Alfred NESWADBA
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
