05-20-2017
03:42 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
05-20-2017
03:42 AM
Is the viewpoort locked - unlock it, there should be a symbol of a padlock in the icons at the bottom right of your screen
With the viewport active, start the line command and type the coordinates 0,0 as the starting point and draw a line to the center of the screen, now go back to model space and see where that line is in realation to your drawing. It might show up that there are problems in the drawing.
In model space if you use the mouse double click what happens, if everything vanishes then that's a problem that can be sorted out (undo) but shows a possible solution.
And the simplest last how did you create the viewport, and are you sure it is the viewport that is selected.
