Alfred.NESWADBA
en respuesta a: Anonymous
>> Neither when i double click with my mouse weel in the viewport
What happens if you change to modelspace and make there a ZOOM EXTENTS (double click the mouse wheel)?
If then the content also seems to disappear it's just a sign for you have geometry objects far away from each other, and so a ZOOM EXTENTS makes these objects so small (on display) that you can't see them.
That can happen with missing XRefs (which are inserted at 0,0 while your geometry is at higher coordinates) or you have inserted something like a block at 0,0 or similar things. Looking to point 0,0 is always a good check.
You might also try <CTRL><A> ... that selects all objects and in case the number of objects is not too high you should see grip points even if the geometry is too small to be visible.
And yes, uploading the drawing will give us the option to show you the solution instead of just guessing.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
