swieciakpawel
en respuesta a: Anonymous
Hey,
Thanks for the information! If it was entirely made by AutoCAD, then I see only a single explanation for this behavior at the moment.
It occurs for a reason not entirely clear to me, that spline was created during Your process because of some bad AutoCAD interpretation of Your 2D sketch. I've been playing with it for a while, trying different combination of following: selection order , mirroring , join, boundary, explode. So far I've been able to reproduce it once or twice after like  50 tries, so there probably is something that causes the issue. I would either guess it to be duplicated entities or properties inheritance, due to selection order while joining objects, that causes them to be converted to splines as a result.
From my side i would only recommend checking the type of the entity that is created before extruding it. When I'll have time, I'll try to dig in more.
Thanks for great feedback!
Kind Regards,
Pawel
