07-22-2015
10:02 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
07-22-2015
10:02 AM
Weird: and this problem is in ALL files? Even if you start a new one, draw a few lines, then start PROPERTIES and select them?
Are you running an add-on to AutoCAD?
Is DEMANDLOAD set to 3?
When PROPERTIES is up on screen and you type OPMSTATE, does AutoCAD show the setting as 1?
Can you see the object properties in the RIBBON (Home Tab, Properties Panel) if you select any objects?
As a test, if you log into Windows as another user, does the problem persist?
