311 Vistas, 3 Respuestas
PDF Publishing Text Issue
Morning Again,
Just realized that attachment with issue was not added to original post.
john.vellek
en respuesta a: Anonymous
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
It seems this was not added to your original thread.
Are you using AutoCAD 2018 and publishing using the built in DWG to PDF driver?
I assume the text in question is annotative scaled. Is it inside a block?
Is it possible to add sample drawing that displays this behavior?
John Vellek
pendean
john.vellek
HI @Anonymous,
Apparently you had started more than one thread on this issue. The solution for your PDF publishing issue was to up to update your AutoCAD to 2018.02
John Vellek
